xjdriver
- Sep 10, 2012
- 341
The clean looking plug is the one that is firing I just put Iit there for reference. The nasty looking one is from the problem cylinder compresion is also around 10psi lower than the rest in no2. First off it never ran all that smooth at idle, after 1000 miles it will start misfiring at idle when first started on the no2 cyl. If I just buy 1 new plug and slap it in im good for a while im just gettin tired of going around the problem. Ya I over did the anti sieze but I dont think thatsthe problem. I think I might be burning coolant in that cyl but I didnt think that would couse sparkplug to not fire. Also It doesnt misfire off idle unless I dont change the plug when It starts missing at Iidle. Cap rotor and wires are fairly new.
Okay, okay. The full story 140000 on the motor ive owned it for 3 years and i really have never had any major problems, i have noticed coolant disappearing but always seem to have a coolant leak somwhere, its also been doing the missfire at idle (for about 30 sec when first started) i traced the misfire down to cyl 2 and noticed the whole wird looking plug issue so i ran compression and found it to be around 10psi lower than the rest (not critical according to Chrysler). I just wanted to see if someone could pinpoint what the condition of the plug meant. And i chose not to rebuild couse when shes completely warmed up idle oil pressure is only around 5psi if that, i think the bottom end is worn and dont want to just rebuild the top. When the time comes im going with a low mile used 4.0, couse i really like the jeep. Motor still runs strong and pulls my starcraft around no problem, so im not to worried right now.
Ive just never seen a plug look like that before.
Its 1998 cherokee, it could have happened before i owned it i suppose but as far as i owned it it never had coolant in the oil. I do believe its probably been overheated, the cooling systems on these Cherokees are a pretty bad design.What year? 1999-2001? Sounds like coolant got in oil and washed out the bearings. That was a major issue with the 4.0 for a couple of years. BTW mine has been running on 5psi or less for years.
I thought a coolant leak would clean the plug so it looks new (steaming it clean)?
Yes thats why I changed them in the first place couse the wires didnt look b ad when I first got it, then it started idling rough so I did a tune up, then a little while after same problem. Ive just*been changing that one plug out since then. Coolant is green, I have to top off the bottle every few weeks.To me, that plug looks fine and I would be suspecting a weak ignition for that plug.
I know the OP says fairly new for the plug/wires but have they been changed since this started occurring.
Ya im thinkin either cracked head or somethin with head gasket on no2 cyl.im not gona tear into it couse mainly of the low oil pressure, lower end is also a little noisy. Its my dd so if it dies im going with a used motor as long as I hear it run first.
