Re: Need help restoring a classic whaler. (pics)
The very first thing you have to do is to get it weighed. Then you need to find out what the hull should weigh. The reason I say this is that it sat out in 8 years of rain (and snow if it snows there). The foam used in those old Whalers absorbed water, and if there is any defects in the inner sole of that whaler, it will have had 8 years to soak in the water. The end result is that not only do you have a boat that will weigh a lot more than it should, but it will not be a safe boat due to sitting too low in the water and not being able to float when swamped. The unsinkable legend of Whalers is true, but not if the foam is fully saturated. <br /><br />If the hull foam is not saturated, you have a good bit of cosmetic work to do. There is a guy on here that took an old Whaler like yours, fixed it up by repairing all the damage and re-gel coating it. It turned out absolutely flawless, but it was a bunch of work.<br /><br />The motor is easier. If it turns, you just need to replace the water pump impeller, clean the carbs, change the lower unit lube (fix and lower unit leaks), and it should be fine. Those old OMCs are great little motors. I have a number of them, older than that, that I have rescued with minimal effort. Good luck, keep us posted...
