kbh121956
- Jun 30, 2013
- 488
Jombee, I would check the Chryslers harness for how many wires and the colors of the wires. See if it is the same as your Force harness. If it isn't, remove the Chrysler harness and install the Force harness. You will need the tach for the Force, the Chryslers tach will not work proper. (Jerryjerry05), if my memory is correct I seem to remember a separate smaller harness of 3 wires running along side of the main ignition harness for the tilt and trim. It has been 2 or 3 years since I did this.
