Hello,
I just got this motor to re-power my 17' pontoon.
Previous owner had dealer install it on 1968 boat year ago, but he never finished the boat and wanted to get rid of the whole thing, so I got motor with boat and trailer attached to it.
I had bunch of OMC motors from 6 to 40 HP , but the youngest was 1977.
This 1994 is more complex and has VRO system I am new to, so I am learning it now.
Before I took it off the original boat I tested compression (151/150), put new plugs, new gas and new oil. Motor sneezed and ran fine in the tank.
Just to be sure I took old boat to my home lake and ran 28 m/h with no issues.
I was happy and disconnected controls, cut off VRO oil line and put it on my pontoon trying to keep all as it was.
I expected it to work fine since it was exactly the same , except I used tank with 50:1 oil mix as instructed by manual until I make sure that VRO works.
It does not start.
I took off carbs and cleaned them.
I took off primer solenoid and tested it as per manual.
I followed exactly steps in the Repair manual for Sync and Link adjustments and remotes connection.
Carbs get filled with fuel, so pump is fine I believe.
I disconnected primer hose from top carb and it spits fuel when I push choke in.
I did put gas into cyls and tried - it did not run.
But ignition is working, because when I take screwdriver and put is to open throttle shafts just a little it starts and runs ( a little rough, but runs).
According to instructions both throttle plates are completely closed when engine starts and it is how it supposed to start , but it does not. I would think that it needs air since when I force throttles it runs.
At this point I am not sure what is wrong.
Can anyone advise on what to try?
Thanks.
It does not start.
Thanks.
