need help with cylinders
Benny1963
Re: need help with cylinders
you could go with used powerhead one on ebay now but ya have to check out what ya buy if your mid and lower are good as well as electronics
then you may be able to do something if its salt water mota then it will turn into nighmare broken bolts and soforth just on powerhead swap.
buy ya a good used motor like i said a lot of the bigger motas are cheap
old crossflows 175 150 from 600 to 1500 theres a gt on craig list with supposed good comp numbers for 1200 with prop says runs excellent
properly maintained its on a boat and is offering sea trial as well
thats what you are looking for run comp check check lower for water and nice long sea trial should idle well start cold without hassle
shift smoothly and pull to wot smoothly
