Re: Need Help With Force Motor
Timing shoud be checked at cranking speed at WOT in neutral with plug wires pulled off. I bought a little spark tester plug from Advance Auto Parts and put it in #1 wire to complete circuit. Clip your timing light onto #1 plug wire. Connect black and red clips on timing light to battery. Put your shifter in neutral and WOT. Have someone crank the key and shine your timing light on flywheel side where the "window" is for checking timing. You will have a mark on a pointer/plate to compare the marks on the flywheel to. I think by the Clymer manual, Prestolite ignition is 28* and Thunderbolt is 32*...not 100% on that though. Oh, I put my water hose on the motor just to be safe with the impeller while cranking!
