Woodonglass
- Dec 29, 2009
- 25,930
Re: need help with glass and resin info/HELP!
Epoxy does not have styrene to break down the CSM fibers and thus will not create the chemical bond that it should. 1700 Biaxial cloth is normally used with epoxy and not 1708. CSM is not usually required when using epoxy. However there are CSM materials that can be used with epoxy but do not yield as strong of a bond as using a lightweight 6 oz cloth. For me, using CSM with epoxy is a waste of expensive Epoxy resin.
