imported_rusty
- Jun 27, 2005
- 186
ok should my hub be up tight against the axel to keep the grease seal from slipping out ? or do i need new grease seals? as you can see in the picture its coming out I replace them 3 weeks ago and these are the rubber ones. should i use the ones with the metal on the outside for a tighter fit in the hub? thanks
