Two days ago I decided to change the impeller on my trolling motor but couldn't get the extension off so had a very hard time getting access to the shift linkage bolt. Took boat out and noticed no water coming from tale tale...figured smashed grommet or misaligned water tube so back at it I went. But now I am determined to get the extension off and have gotten it a lot farther but it won't go any more.
My questions are..
a) Do factory long shafts have different water tube setups than factory short shafts that were converted?
I have two of these motors and I am "thinking" my other motor was a little different but not sure.
b) Is the water tube I am working on supposed to fully come out of the extension or is there a joint above it and a small piece of the tube stays in the extension?
Rephrased: Is the end shown in the photo here permanently attached or is this just a hole it slides in?
I am just not sure where this is "supposed" to come free and do not want to break, bend or damage anything while trying to pry pull and pray...lol
Thank you.
My questions are..
Thank you.
