Need help with wireing!!
wilson750
I just added a 2002 75hp merc 2stroke on my skiff..I do have a seloc manual (bought from Iboats) and did not see/find any sort of wire in my harness for a low 2 stroke low oil warning? I can not find anything in the manual also..Does anyone has any info to help me out with this?
CharlieB
Re: Need help with wireing!!
Do you think this may be one reason we STRONGLY recommend only FACTORY service manuals?
Check these links to see if yours is available
http://1manual.com/Mercury manuals/Service_Manual_Index.html
http://forums.iboats.com/showthread.php?t=309079&p=2072211#post2072211
If your motor has an oil tank there should be two blue wires coming from the low oil switch in the bottom of the tank. These two wires should connect to a black box, the oil alarm module, which will have wires connecting to an oil pump rotation sensor, one of the ignition coils, and the motor wiring harness.
carholme
Should be a black wire to grd off the oil level switch and a tan/light blue wire connecting the level switch and head temp switch going forward to the warning horn.
What is your engine s/n and what control box are you using?
Gerry
wilson750
Thanks Guys
The Ser# is 0T508685 Its the quick silver box? Its a center console box.. hope that helps
wilson750
Is the warning horn going to be the low oil now? Or makes the warning horn sound?
carholme
That s/n comes up as a model:
1075412ZD MERCURY 2002 75
Parts listing:
http://www.crowleymarine.com/mercury-outboard/3374.cfm
SErvice Manual P/N: 90-830234R04
http://1manual.com/Mercury manuals/Service Manual PDFs/TwoStroke/830234r3/cover.pdf
You must have Adobe Acrobat reader installed to use this manual. If you scroll down to the lower part of the opening page, you will see the various engine components in red. Click on the one you want and when the first page opens, click on the "Save As" icon at the top LH corner of the page and you can save it to your computer.
Look under Fuel System (Oil Injection) and it will show the wiring, tests and warning horn system for the low oil level. You will also see the Low Oil/Overheat Warning module which provides the two signals through tan and purple wires to the warning horn.
Gerry
wilson750
THanks for your help carholme i am going to give it a try this week with the info you gave me..
drtrotter74
Parts listing:
Gerry
Great info. I have been looking for this also. I see that my motor, which is a 2001 75 ELPTO does not have the warning module. I traced the wiring all over inside the engine cowling, and no dice.
Then, I read this somewhere else in the forum that Mercury stopped putting the warning modules in this edition of engines sometime after 1997, when this manual was published. The low oil and overheat still have sensors, but there is just no module, that would allow you to get the self-test buzz, when you first start the engine.
Anyone know if there are current service manuals that have the latest configurations in them?
Thanks,
Dave
carholme
Dave;
Look at the wiring diagrams from the same manual and see:
1998 75/90 Electric Start w/Power Trim Wiring Diagram
Gerry
drtrotter74
Dave;
Gerry
Hey,
There ya go. I guess I just did not scroll down far enough when I opened the .pdf files. I figured it out anyway, but it is nice to know that my complete wiring is detailed somewhere. I still have to test my warning buzzer to make sure it works though......wish they could have left the module and the self test capability in there.
Dave
