Need Help
Scotch
Will a 8hp.motor plane off a 12ft. aluminum boat if so how do I go about it? I am going to put more weight up front like a 12 volt battery before I go out again fishing. I have down size in boats, never had this problem with last boat. Thanks.
tx1961whaler
Re: Need Help
Battery up front, fuel tank up front. Play with the motor trim angle adjustment. Make sure the motor is not too low. The anti-ventilation plate should be even or slightly above the bottom of the boat. Use a yardstick or long level, eyeballing it can be deceiving.
Bob_VT
Re: Need Help
Another alternative is to get a tiller extension and you move your body weight forward too.
5150abf
Re: Need Help
I had a 12 with a 9.9 and as mentioned, I got a long gas hose and put the gas and battery all the way up front and it worked really well, that should help alot.
But yes I would think it should plane out eventually.
