Need Info on Mariner 15HP
Eppinett
I looked at the chart on the japenese link and cant find the year.15m, sn 684cs02619. Just accuired this little motor from my uncle. I need to clean the carb, new plugs and the pullrope needs to be reworked. HOW DO I CLEAN THE CARB AND REWORK THE PULLROPE?<br /> John
rickdb1boat
Re: Need Info on Mariner 15HP
eppinett <br /><br />I would check that serial number again, as I cannot find it either. Maybe the "S" is a "5". Nevertheless, you need to order a rebuild kit for the carb and remove it from the motor to clean it. Sometimes, if it's not too bad, you can dump some "Seafoam" in the gas tank and clear it up. do a search at the top of this page for Seafoam. As for the starter, I would not want to give advice on that because it can be dangerous to service if not experienced. I would take it to a small engine repair shop and let them deal with it. Also, a Manual for you're motor would be a great help.
The Marine Doctor
Try this # when looking up parts.<br /><br />M-684-000101 and up.<br /><br />This should find you the parts you need.<br /><br />TMD
Eppinett
Thanks Doc, and others. I have been through my omc 9.5 1970. But this Yama/Mariner is built totally different.
Eppinett
Found a new number. So the sn is 684cs026194 and I am thinking this is a 1982 model.
