Any ideas what this engine is worth?
The compression is cold:
120psi top and lower Capt side,
118 psi top and lower pass side.
The lower unit oil came out with no water, it was green with some fine metalic in it. Stunk like gear oil should.
I heard run with muffs. But I couldn't tell anything from that but noise and smoke.
It had a 3 blade prop with this mumber on it: G 1074
I took other pics if it would help
