Mark42
- Oct 8, 2003
- 9,334
This winter my big indoor project is to install hardwood flooring in the Living room and Dining room. Its been about 20 years since I did a hardwood floor install, and I'm sure some things have changed, and I just plain forget about the details.
Plan is to use pre-finished hardwood in Maple or Ash. Going with the traditional 3/4" tongue and groove stock, and its going down over a plywood sub-floor. The existing sub-floor is 23/32" T&G "Sturd-I-floor" ply rated for 24" joist spacing, but the joists are 16" O/C. The floor is glued and screwed to common 2x10 floor joists. Will add more screws just to insure that the sub floor won't squeak.
For prep, I was just going to add screws every foot, and using a 6 foot long piece of 3x3" angle iron, check for high spots and sand them down with a power sander. Maybe fill any low spots with some floor leveling compound. Don't think there will be an real problems in this area.
Here is where I need some guidance and updating on methodology:
1) Covering the sub floor - What is better, tar paper, the red paper, or the thicker composite papers? The basement is finished under these two rooms and the joists are fully insulated using common fiberglass bat and then a 2x4 foot ceiling tile finishes it off. This setup really insulates the first floor from basement in both sound and heat.
2) Nails or staples? Will rent a nail gun, I think the local rental store has electric models. The maple and ash woods are even harder than oak, and I don't want to end up splitting boards left and right. Is this something to worry about?
3) After letting the wood acclimate to the house temp/humidity, how tightly are the strips fit together before nailing? Are they driven tight, or just fit loosely?
4) Which end of the room to start laying the flooring? The flooring will be laid perpendicular to the floor joists. That means in both rooms, there is the choice of starting at a wall with a base board heater the full width (which were installed high in anticipation of the carpet being replaced with wood later), or the other end where there is no heat register, but has a 6' archway leading to tiled floor.
5) Transitions between rooms: Both rooms connect to tiled floors. In the archways, the tiles were run just short of the center of the archway wall. Right now a pre-finished wood strip connects the carpet to the tiles. New transition trim will be needed to match the new floor color. The wood floor with be about 6/16 to 7/16" to higher than the tiles. Will a T strip make that sort of transition well or is there something else that should be used?
Been searching the net for floor install directions, but nothing I found is answering all my questions well.
BTW, these are fairly medium/small size rooms (12x12 and 14x16) and I am doing the install myself so I am willing to spend more to get "select or better" grade wood. Also don't want to use boards less than about 2 feet. I see some specs list lengths from 9" up to 5 feet. No way am I installing 9" boards that are 5" wide!!! That will look too "economy" for my liking. Plan to use a wider plank, like the Bellawood 5" wide maple in natural finish. So short boards will really stand out. The specs say to figure a 5% waste, but if only longer boards are being used, maybe the waste factor should be more like 15 or 20%? Yes, no??
And last, what are suggestions for a good supplier? The Bellawood from Lumber Liquidators looks nice, and I can pick it up from the "local" store (about 45 minutes away) and save shipping charges.
Thanks!
Mark
Thanks!
Mark
