HotTommy
- Mar 15, 2013
- 1,025
I have finished restoring my 1993 Force 150 outboard. I've run it at idle for more than an hour in my tank, and it starts on the first try when warm. But I haven't mastered the optimum technique for a cold start. .... The system has a prime circuit rather than a choke, and the prime circuit appears to be working. I can hear the solenoid click when I press the key inward. I've tried various combinations of fast idle and holding the key in for anywhere from just a moment to several seconds, but I haven't found the one that consistently works. The only thing that works consistently is to give it a brief shot of starting fluid along with fast idle on the throttle. In those cases, it fires right up and idles at a very fast speed for several seconds. ... I don't know if the oil-rich 25:1 break-in fuel is harder to ignite than 50:1, but regardless, I need a better starting technique. Can anyone recommend one or a method for finding one that doesn't require multiple days of trial and error testing?
Tommy
Tommy
