Like_mike-ike
- Jul 5, 2011
- 5
When towing the boat, should you have the motor in neutral or in gear?
When towing a boat or anything else you should most definitely be in gear.... If you are in neutral you'll just sit in one place revving your engine.... now the boat..... it makes no difference whether it is in gear or not since it's "wheel" isn't touching the ground so you may as well leave it in neutral![]()
When towing a boat or anything else you should most definitely be in gear...![]()
A friend of my dad's suggested he put the boat in gear before a 250 mile tow. For a long time after, he had problems with getting the boat out of gear while on the water. I'm not really sure what the actual issue was, but can't help but think towing in gear was a major contributing factor. I'll always tow mine in neutral.
I either put mine in forward, reverse or neutral depending on which direction the wind is blowing. For example, if there's an east or west wind when we're ready to pull out and we're going north or south I'll put her in neutral. That way the prop won't be working against us in the side winds. Conversely, if there's a north wind and we're heading south I'll put her in reverse before we leave, while heading north into a north wind mandates forward. Same goes for heading south into a south wind. I won't get into drag coefficient and that sort of thing.
I'm suprised you don't also use a transom mounted adjustable spoiler with a turbine duct to the prop to capture that wind effect to blow some of the hot air out of your driver seat...
