new 2002 150 e-tec
erniefish
i am putting together a boat for my buddy, he has found a new 2002 150 e-tec, i know they are bullet proof now, but what about the older ones, was that the first year? thanks for any info, eric
BaileysBoat
Re: new 2002 150 e-tec
Are you sure it's not a FICHT? The E-tec didn't come out until 2003.
boobie
I think you should get a model # off of it before he buys it. If it's a Ficht stay away from it.
Agreed
They were on the right track until they went bankrupt and then the BRP family brought them back, Fichts were high maintainence for example spark plugs had to be changed every 100 hrs, exhaust/baro temp had a tendency to get clogged and had EMM problems. Etec is probably the best choice in my opinion for the bass guys because you can stock up on batteries for trolling motors and accessories. The software is nice and was designed by a former marine mechanic.
seahorse5
Get a model number first. There were no E-TEC 150's in 2002, only the FICHT engines.
Now the 2002 FICHTS were built by Bombardier and were very good motors in their day. The 2001 and earlier FICHTS were built by the former OMC and had a checkered reputation.
erniefish
ok here is the info model#150fpxsnf, serial# 04996051, i hope this helps, these figures were sent to me i hope they are correct
boobie
It's a 2002 direct injection Ficht with a 25" shaft. As said above, BRP manufactured these and it might not be to bad. I'd still stick with an E-Tec though.
