Hello everyone!
I just bought my first boat, bought it out of a barn for $140. She is a 1968 or 69 Shell Lake Lasebra 500. Its got some work it needs before I get it in the water and want to get some opinions before I crack into it.
The engine: 1968 Johnson 40 HP Electramatic Model Number: RKL-30 A, serial number: J2975493, I pulled the engine cover off and started it taking a peak, looks like a mouse mad its home inside and started eating some wires. Checked compression 92 in top cylinder and 102 in bottom (good or bad?) See below for images
My questions:
- Where should the fuse box typically go on the wire loom up the the steering wheel, because I can't find it of previous owner?
- How does my engine charge the battery back up, it doesn't appear to have the generator?
- On my carburetor it looks like its missing the the spout to that allows me to clamp the fuel line to any suggestion on that?
- I have looked high and low for a correct wiring diagram for this and haven't found one (waiting for my repair manual to come in the mail) any one know where I can find on on the internet?
- I've read on the forum that you need an electramatic control to make the clutches engage etc OR when that switch breaks you wire up another three way switch for Forward, natural and reverse? Is that possible? I believe thats what the PO did because Found a three way switch on the end of my loom.
-Does my engine have an electric choke?
- What controls should be on my instrument panel, the boat shows cut outs on the dash for and Amp meter, Push button choke and starter.
Alright enough question for the first round!
Thanks for you advice!
David
My questions:
David
