Navy Jr.
- Sep 14, 2007
- 738
Our new Shorelandr' trailer came with Bearing Buddies installed. Last weekend I decided to check them.
The manual and website says that if you can rock or otherwise move the piston, then the system is charged correctly with grease. If you can't, then you should add grease until the piston cover moves outwards about an 1/8th of an inch.
The problem is the piston covers on both BBs don't move. There's about 5/8" between the outside edge of the BB to the top of the piston cover (under the zerk fitting).
I'm worried the bearings on the axles were properly lubed with grease, but not the BBs. I tried to add a little grease with my grease gun, but the grease would not go in; it just flowed out over the zerk fitting. Then, when I went to remove the grease gun, I didn't angle it enough to twist it off right away and the gun stuck to the zerk fitting such that I could pull the piston cover slightly outwards against the pressure of the spring. I angled the gun off the fitting and cleaned the grease off of the spring.
Any ideas? Am I interpreting the instructions all wrong? I sent an e-mail to Bearing Buddies yesterday, but no reply yet.
Thanks. Ken
Thanks. Ken
