Bt Doctur
- Aug 29, 2004
- 19,484
Re: new coil - still no spark
I`m still leaning to the points install part.
using a meter set on ohm`s Rx1
remove the wire from the neg side of the coil that does to the dist. ,attach meter to that and a good ground, remove dist cap and rotate motor untill points are closed, insert a matchbook between the points to hold them open.
Meter reads:????
Remove matchbook: Meter reads?????
Meter reads:????
