stephenca118
- Aug 23, 2021
- 15
Thought I would start a new thread as the problem is different.
The engine serial #1057HA says this is a 1970 105.
Supposedly this gearcase was rebuilt by a marine shop 10 years ago but never run.
I reinstalled the 12 blade impeller to get the engine started. Installed the gearcase (one piece). Installed the prop, pin, and hand tightened the cone nut by hand.
Putting forward pressure, by hand, on the prop and rotating it causes it to bind on what I am guessing is the zinc anode, per the picture in clymers.
But of course the picture is different than what I am seeing. Or I am missing some parts?
Per the picture breakdown on page 354 I am missing a prop spacer, flare washer, plain washer and stop nut.
But I have a pin that goes through the prop hub and the splined shaft.
I am thinking this illustration is for a later model?
I may also be missing a forward gear thrust washer.
I am not apprehensive about tearing into the gearcase but the book calls for a lot of special tools. Anyone have luck improvising in place of special tools?
Attached are pictures of what I took apart. You can see the scrape marks on what I think is the anode and only in one spot. I rotated the prop 180 on the shaft and the mark is in the same spot. Bent prop shaft?
And should I unpaint the anode?
Thank you for any feedback,
Steve
I will attach pictures of what I took apart.
Steve
