sea_goin_dude
- Mar 15, 2011
- 55
Re: "New" Led Submersible Boat Trailer Lights won't work
AND if you only use tape or shrink tubing, water (fresh or salt) will, by capilary action, find it's way up the wires inside the insulation and do even more damage. Later when you might need to replace that connector and trim the insulation back, you will find your wires coroded and have to cut back even further and maybe have to splice on wire because what you have is too short to make your connection.
So the thing with the caulk or rtv so you do seal that connector and prevent more damage to your other wiring. Crimp connectors are great but always solder the connector anyway.
If any of you use shrink tubing on your connectors, before you heat it to shrink it, shoot a bit of caulking or rtv sealer in the tubing, with the connector and when the tubing shrinks, it will squish the sealer all around and through the connector and really "seal" it and make it water proof. Otherwise, water can get inside regular shrink tubing and while you can't see it, your conectors still rust, corrode.
