New motor!
jitterbug127
After some recommendation from another thread I decided to get at 6 HP long shaft motor as my back up motor for the river. I got lucky and found a really nice 1979 6 hp Johnson right up the road from my house. It had new fuel lines and new fuel pump already on it. I rebuilt the carb, installed new spark plugs and installed a new pull rope. I have an impeller on the way. She'll be ready for fishing season. 90/90 compression and STRONG spark.
Crosbyman
that is what anchors are for should one be so unlucky to have both engines give out...just bring a phone to :)
cookie said
"always fish upriver ! "
jitterbug127
Hopefully it's a tame river, wouldn't want to rely on that little beauty in a " hey I think we are going over the falls" condition!
Smaller size craft I hope ?
It’s a 16x54 Jon boat: I won’t ever use it as an actual kicker. This is just my emergency get back up river motor.
Crosbyman
if you troll big lakes a nice humming 6hp is great and generates less fumes from a back wind & noise. Set it straight with the friction bolt and steer with the big guy :)
JimS123
Isn't that the actual definition of a kicker? If you have it mounted on your transom alongside your main, then it's a "kicker". If it's not mounted, then it's a spare.
I had that exact same motor as my kicker on a 16' deep V fiberglass runabout. Mine was s short shaft, though. It was mounted next to my 75 Johnson Stinger.
You know why I had that kicker? Because the main broke down once on the Niagara River in sight of Niagara Falls. That part of the river has a very hand bottom and trying to anchor there ain't easy.
jitterbug127
I don’t know what the actual definition of a kicker is 😂. I was thinking people used kickers from trolling but I’m still pretty new to boats. I take my son fishing on the river often and done want to get stuck down stream. It can be pretty shallow in spots where we’re at too.
JimS123
Been boating since the 1950's. AFAIK, the terms are pretty universal.
A "Kicker" is a gasoline powered small motor mounted on the transom next to the main. Some people use them for trolling, with a secondary purpose as an emergency backup. Regardless of one's purpose, it's on the boat and ready to go at all times.
Optionally, some boats are equipped with an electric motor, usually mounted on the bow, and almost exclusively used for trolling, thus aptly called a "Trolling Motor". That said, though, many of the newer higher powered ones can be used for emergencies as well.
To further complicate things, "Trolling" has different meanings as well.
When I drop my kicker and set her to 1.9 mpg I throw a long line out the back with a plug on it and I TROLL for muskies. Alternately, when I'm moving along the weed beds and casting with a spinning rod, I use my electric foot pedal mounted trolling motor to move around in all different directions.
Thus, when your fishing choices vary, having a troller and a kicker on the same boat is the cat's meow.
JimS123
better get a new kicker to save fuel ... :)
Real Value Comparisons:
Course:
6 mile no-wake zone + 8 miles upstream at WOT (as conditions warrant)
Fuel: 87 octane E-10
1952 25 HP Outboard - 9 gallons
1978 75 HP Outboard - 6 gallons
1984 140 HP I/O - 4 gallons
2019 150 HP 4-stroke Outboard - 3 gallons
Beaver Oars - 1 gallon of sweat and 4 Budweisers - priceless (but didn't make it past the no-wake zone)0
(PS - that is a pretty good comparison on how marine propulsion has evolved over the years. What isn't figured in is the massive reduction in dB along the way.
saltchuckmatt
I have an e-tec....because I fish and boat mainly in Puget Sound (don't know where that is? Look it up, Puget Sound in Washington state) and the Pacific Ocean I mainly troll with my big motor. I always have a "kicker" next to the big motor just in case the ocean wants to slam me into big jagged rocks where these guys live.
Extremely tasty!
JimS123
set for 1.9mph maybe but at 1.9 mpg for a kicker ...? check for leaks
The motor will push the boat at about 6.5 mph. When we go fishing we run at about 1/4 throttle to make the lure attract fish. 1.9 mph is the ideal fishing speed, not what the motor is capable of.
JimS123
Extremely tasty!
Nice catch. We are in fresh water. Keeps the boats and equipment in nice condition, but our catches don't compare.
Our required speeds are slower than the Mercruiser can handle. That's why the 9.9 'Rude came in handy.
Even a 10 year old can join the fraternity....
