bigblock454
- Apr 28, 2008
- 206
Hey team. I'd like to ask "is it acceptable to construct transom out of the boat, using PL glue to laminate the two 3/4" pieces, wrap with polyester resin and csm, then use epoxy and glass ONLY to glue the lamination to the existing transom skin, then complete the procedure using poly"? I already have some "structural adhesive" epoxy from Glen-L, left from another project. That way I would get the good "secondary bond" offered by the epoxy (I know epoxy bonds well to poly, but not other way around), and then complete the transom, floor, and stringer using polyester. Otherwise I could just "bite the bullet" and use epoxy throughout, but UGH... the extra expense! Actually, I haven't tallied anything up to see "how much more" the epoxy would cost over the poly. I just remember being floored with the cost "by the gallon"! Still not sure how much of anything to order, but really want to order it! Guess I'll brush up on my math skills. Again, the "floor" is basically a 4 x 8 sheet of plywood, covered with what appears to be roving. Never worked with that stuff before. Is that what I should be using to cover the new floor with? Under that is a single central "stringer", that I expect to be gone. The only reason I don't know for sure is I want to have new transom in before I tear out the other "structural members". I believe this type of hull uses that 4 x 8 for structure as well as a place to mount seats! Thanks for any input!
Norm
Norm
