- Apr 17, 2002
- 71,423
Re: New Starter Just Spins
Ayuh,... Welcome Aboard,... Ya get the same answer for this Hi-jack too....
So I finally swapped out my starter after the last one which would spin and then grind and take forever before actually getting the boat to start. I inspected the flywheel and while there were some chips I didn?t see any major damage such as missing teeth. After getting the new one all set up I connected the power and it seemed to engage the flywheel just as it should. I brought my boat out, connected the muffs, and tried starting again. The first few attempts seemed good but on my last try it seemed to bind a bit. Now when I turn my ignition the starter just spins and it seems the bendix isn?t popping out to engage the flywheel.
I am going to pull the starter again to inspect it but does anyone have any clue why a new starter would all the sudden just spin and not engage they flywheel?
Thanks!
originally posted by Don,...
Welcome to iboats coquitec,
Please do not hijack someone elses post to ask your question on, if you have a problem, start a new thread with all your information, then you will at least know if someone is answering your question or the original posters question.
