I had a 10 year old starter slave solenoid from a Mercruiser 3.0L go bad and replaced it with a matching aftermarket part. That solenoid lasted 2 years and went it ka'-put, no engine start, no click, nothing. The small lugs on the solenoid show infinity resistance between them so the coil inside has a broken/fried wire, same as the original Mercruiser part.
Do I have bad luck or do these solenoids fail that often? I had an old style slave solenoid on a 72' 140HP Mercruiser that was original and still working after almost 40 years!
It's a real pain to replace the new style slave solenoid on my 140HP Frankencruiser (nuts behind a plate with little clearance) and I'm thinking of replacing it with an old style solenoid if they are more reliable. Either that, or I'm going to order 2 of the new style solenoids, for when it goes out again...
