Re: new to boating, you folks already helped
All camshafts have overlap built into them. Overlap is the time in which both intake and exhaust valves are open. At higher rpms usually over 1500 that overlap doesn't matter to a wet exhaust system since the exhaust gasses can't be drawn back into the cylinder, they are simply going out too fast. At idle, however, that overlap can cause inversion if it is too long. A 'lopey' cam can cause exhaust and therefore water to get pulled back into the cylinders. What happens is at idle the piston has been pushed down by the power stroke and the exhaust valve opens. As the piston travels up exhaust gasses are pushed out. As the piston gets close to the top of its travel the intake valve starts opening and some exhaust gets pushed through the intake to be drawn into the intake stream of other cylinders. As the crank and rod rotate through the TDC arc two valves are open and the other cylinders are drawing air wherever they can including that open exhaust valve. Then the piston begins it's downward travel for the intake stroke and starts pulling in it's own air supply from both open valves until the exhaust valve closes. On a high duration camshaft put into an engine designed to use it at high rpm, adjustments are made for a high idle speed so it will 'idle', usually at 1000 rpms and up. For our marine engines, a 1000 rpm idle speed is not feasible since we have to shift our drives at that speed. Docking would be difficult. If we had clutches installed we could idle at 2000 rpms and never worry about inversion since the 'lope' wouldn't be present and the 'scavenging' benefit provided by the high duration cam would keep water at bay. Hey, water at bay... in the bay.. yeah ok very punny. Anyway, the high duration camshaft benefit is at higher rpms. If you are propped for, say, 4800 rpm, you'll still only get 4800 rpms, and your low end grunt will be less. Stay with higher lift and same duration if you must change cams. Be sure you will have enough piston clearance. A voice over the phone from a cam manufacturer is not gods word.
