As usual, I've jumped off into a boat that looked pretty good sitting in the other guy's yard only to find out it has LOTS of issues.
The gas cap has a broken latch, so I ordered a replacement gas filler/cap unit for it only to discover that the old one was installed before the top half of the boat was put on. Can't get to the hose clamps under the deck in the back corner to get the old one out. I've tried groping a screwdriver to the clamps and can touch them, but not turn them.
All three batteries were dead, so upon replacing them I found that the aerator switches on the panel are lit up whether they're on or off. One pump for the live well was wired direct to the battery, so it ran full time. No wonder the batteries were dead.
So far I haven't gotten the trolling motor to run, may just be a matter of figuring out how the batteries need to be hooked up.
The bilge pump may or may not work, assuming it has a float switch, so it may need water in the bilge to run.
The only things that seem to work as they should are the bow light and instrument lights. Stern light doesn't work.
On the good side of the ledger, I took my compression tester with me and tested the engine before buying it. Three cylinders were 110, one was 120. I also took a good battery with me and started the engine with muffs, and it started and ran fine.
Looks like my fishing won't start until well into June if then. :blue:
