FirstRealBoat
- May 24, 2015
- 126
This is a 1967 Evinrude 18 HP. My comment will be with the pictures.
Thanks for looking and your replies.
Data Plate. Looked up number 1967 it is.
Dirty it is!
This is on the side to the LU, what does it go to? I can't seem to understand the service manual I downloaded for this model.
This was nasty! Looks like the stop screw is broken, actually it fell off while I was cleaning it. Now what?
I don't under stand this throttle at all. It has a flat spot and only turns 180 degrees if that?
Missing the adjustment, have to take the cover off to adjust the mixture. Where can I find this part? I would like to get this working right.
Nice cable tie....bwhahahah, I will be changing this. Do I need to rebuild the fuel pump? or just clean it so and put back together?
Hole with missing adjustment screw. I whipped this off several times to get it this clean. This thing had so much grease on it! Nasty over greased everywhere!
Linkage was covered in grease..... But new wires for shutoff button! That's one thing that clean...haha
What does this lever go to? It is spring loaded but not attached to anything?
Nice weld job, it is solid, but not clean. Hope it holds!
Thanks for looking. I will take more pictures as I start to clean carbs and pull LU for water pump replacement.
This motor runs as is, but doesn't pump water. So I shut it off after 3-5 seconds. The service manual I have isn't very informative. What is the best way to take the LU off and replace the water pump? What do I need to watch for? Is it as simple as drop it, slide off shaft and replace with new gaskets and impeller and put back on?
I can't seem to find any video's of these engines being worked on like I have for the JetSki and Mercury motor.
Thanks for looking.
Dirty it is!
Thanks for looking.
