Re: New to PWC, stuck between 2012's Seadoo GTR 215 and Yamaha VXR
Well, they are both fast (upper 60s). The Seadoo in a more complex machine. It uses an Austrian built Rotax engine, has a more complicated closed loop cooling system, and is supercharged, and so you may have some issues to deal with down the road with that. I think they have solved the ceramic washer issue that used to plague their supercharged skis, but I'm pretty sure the supercharger will have to be rebuild after a certain number of hours. The Seadoo will have lots more stuff (trim, brake system, cruise control, etc..). That is also more stuff to break or cause problems down the road. It will also put more of a dent in your wallet. I suspect that the Seadoo will be a better ride in rough water, by a small margin than the VXR. If you are looking for something to take off shore, I'd recommend the RXT instead. It has a better hull.
The VXR is a more simple design (open loop cooling, normally aspirated engine, fewer bells and whistles). If you plan to do your own maintenance this will be a much easier machine to work on. The 1.8L engine on this ski is a proven design, and is pretty bullet proof. It is the most fuel efficient ski on the market that is also capable of speeds above 68 mph stock (also uses 87 octane versus 91 for many Seadoo models). All the other skis that can reach this speed are supercharged and tend to be a lot more thirsty. Down side is that the VXR has a flatter hull, and gets bouncy in rough water. It is a great ski for a lake, but you will get wet and beat up off shore. The FX HO or SHO are better choices for ocean riding from Yamaha.
