Stachi
- Jul 14, 2009
- 1,671
Re: newb of all newb questions
Find your batteries... clean the terminals and posts... and then charge them ...that clicking noise from the starter motor is a result of low voltage. A good battery should read 12 -13 volts with engine off, not 8 volts. After it starts and is running, check the battery terminals with a voltmeter...you should see something over 14 volts if your alternator is functioning properly....report back with your results...welcome to iboats
It cranks about a 1/4 turn and then I just hear a fast clicking. When I turn the battery selector guy (1/all/2/off) to 1 (volt meter at 8 volts which is the lowest it will display) all the lights dim and not much happens and when I turn to 2 (volt meter around 10 volts) the lights get a lot brighter but it still barely or doesn't crank so my first step tonight is to get the batteries tested.
We did have the boat plugged into the dock and it still did the same thing. The volt meter didn't change either, shouldn't it have?
This is just one of the issues. When it did run it ran pretty crappy so we're thinking the carb is gunked up pretty bad.
When you pay someone to winterize and de-winterize (word?) shouldn't they be checking all this stuff for you?
