Darren Nemeth
- Dec 25, 2007
- 561
After a long winter, I'm getting ready to restart work on the Batboat.
The remaining jobs to take on are repairing and reattaching the splashwell, new Batboat detailings and new paint.
Here is the problem; I know absolutely NOTHING about preparing the outside of the hull. I've come to you guys in the past and the instructions I got were priceless. This project would have never gone anywhere without you at the iboats forum!! Please help me out again!
Basically, what I have here is an average, lightly used 40+ year old boat with scars and dings in the hull. All the structurals are completely repaired.
My main question right now is what do I need to do to the top and bottom sides of the hull before they are ready to paint?
Here is a rough checklist of problems.
* there are the normal spider cracks in the gel coat.
* A bunch of holes through the bottom of the hull that I repaired from inside the hull with many, many oz. of fiberglass but did nothing to the outside.Photos of these repairs are here -> http://batboat.blogspot.com/2008/10/batboat-rebuild-day-13-september-25.html
* the surface of the stern is severely damaged where the engine broke through. These have been fixed with the transom lamination but still has gouges that need to be filled and made smooth. Photos here ->
http://batboat.blogspot.com/2008/10/batboat-rebuild-day-14-september-27.html
* several spots where I flexed the hull with a crowbar from the inside are cracked through the gel coat but repaired from the inside of the boat with many layers of fiberglass. Photo is attached.
Most of the nicks and scratches in the gelcoat are cosmetic except ones mentioned above. The anti-crime water cruiser is water tight.
What equipment, materials and techniques do I need to fix, fill in and make the hull smooth again before I can begin to paint?
Another big problem is the hull was painted with latex-looking black paint. Some of it peels off now but most is on there good. I tried sanding a few spots with sandpaper but the paint gums it up quickly. How do I get it this off?
