Im not very familiar with boat motors so forgive my 'dumb' questions.
These questions are in reference to a 1978 M800 80HP Mercury<br /><br />There are two cables that run into the engine at the same spot. Im just 'guessing' that they may have something to do with throttle. How do I remove these from the engine? I tug a little and there is no give so I imagine there is something else that needs to be done.<br /><br />2- Is there any way to tell how many hours are on these motors? I peeked around and didnt seen any type of odometer.<br /><br />3- My steering seems frozen. I think maybe the 'tube' that the steering arm connects to is locked up. There is a grease nipple here so Im going to lube it up. What should I use for lube? Will just regular auto grease work?<br /><br />3.5- How do I remove the steering cable from the motor? I cant seem to figure out what needs to be done. I see two large brass colored nut type things, one on each end. Do I just remove these and slip it out?<br /><br />I'll be forever greatful if someone can answer these questions.<br /><br />THANKS ALOT!
