I'm seeking advice for next diagnostic/troubleshooting step for my overheating problem.
I installed a rebuilt long block replacing a freeze damaged block. The damaged engine ran and did not overheat, but suffered water in oil and hydro-locking problems.
The new long block is a later roller cam block, and has flat top pistons installed. Other than the bare long bock, most parts were re-used.
The new engine is operational and running smoothly. The engine makes more power than the old one and revved up to 5200 WOT with my 17 pitch prop and started overheating.
I changed up from a 17 to a 19 pitch prop now it maxes out at 4600 RPM.
I replaced the thermostat, installing it correctly. It seems to function correctly at idle and at medium cruising speeds.
I inspected the impeller and it looks perfect.
I removed the transom bracket water hose from the thermostat housing and started the engine, water flow is good.
The engine is still overheating when run over 3800-4000 RPM, or even around 3600 after about 10 minutes. At 3500 it hovers just under the red zone. If I back off to idle, or even to 3000 RPM, the engine cools down to a normal operating temperature with the gauge in the middle of the green.
I don't believe the temp sender or gauge is off, because when it reads hot, the engine starts smelling hot.
Because the water flow checks out, I am assuming the problem is on the engine side not in the outdrive (which,btw only has 385 hours on it).
The ignition timing has been set by hand without a light to the smoothest idle operation by ear.
The belts are tight and working correctly.
I haven't checked for exhaust gas in the water line yet, but again, the problem wasn't there before and nothing has been changed with the outdrive.
The exhaust manifolds and risers are remaining fairly cool until the engine is overheating. The intake manifold seems to be getting really hot.
The intake manifold gasket was installed without restrictors because the old engine didn't have them installed.
The engine, being new, obviously will have clear passages. The intake manifold is clear. The exhaust manifolds and risers are clear except for one of the passages to the riser on the port manifold. (This blockage did not make the old engine overheat.) riser gaskets were carefully installed and should not be blocking anything.
Charles Galt
Charles Galt
