Next Project
zach103
Re: Next Project
nothing done.. works been busy.. butttt
jcsercsa
Re: Next Project
Too Cool ,, you lucky Dog !!! it looks like it might be 6 oz , they dont measure it by thickenss its by weight !!! I not sure what size it is needed might be 1 foot square ??? not sure thoe !! Boy between you and Mike you two could build your own boat !! John
proshadetree
Re: Next Project
Glad to see this thing coming together.From the start picts you would think run its junk.Now you have a very doable project going.I applaud you and your effort so far.
bear_69cuda
Re: Next Project
Bummer photobucket is blocked by my employers server. :mad:
I'll check it out from home tonight!
zach103
Re: Next Project
yah i looked on uscomposites it have oz's and than the thickness of the mat.
zach103
Re: Next Project
Thanks. .. It means a lot to hear people say that.. im pretty pumped that the motor is already done and running.. now i just gotta get movin with everything else
proshadetree
Re: Next Project
I dont think anything I can say will replace the pride you get when you just look at how far that ride has come.Cow pasture to a great resto next step showroom.
zach103
Re: Next Project
so night from hell but i got some done.. i went to tab the string and bilge. well i got all the glass cut. mixed the resin . than realized that i had no brushs.. so i tried using the foam ones.. those stunk.. than the roler fell apart.. so it was all over my hands.. than i had no acetone.. so tried gass didnt work that great.. but 2/3 or the stringer and bilge are done
zach103
Re: Next Project
oh wow its been a while.. not much has happened.. been busy with work and the other boat..(which has a kick *** stereo now) . well like i said not much got part of the first piece ready for class.. caps partially on. idn what else
25thmustang
Re: Next Project
Keep up the work when you get the time. I should be working on mine starting next week. Finally got my car done, and once I pass emissions I can ignore that for a bit...
Nico2112
Re: Next Project
Even if you feel you're doing little progress, I think you're doing a good job:)
Keep at it whenever you have time.
n2ostroker
Re: Next Project
Is that a 73 Evinrude 50?
I have one exactly like it. Mine is pushbutton shift. We use it on a 16ft 73 Bass Master. Great running motor and pretty easy to work on. Looks like some great work you're doing. Nice project there.
zach103
Re: Next Project
25th hows the car.. ive been keeping an eye out for a 65-70 mustang fo really cheap as a project..
thanks nico :)
n20 its a 77 actually
25thmustang
Re: Next Project
Cars good, got the clutch and rear end done the night before the race this past weekend. Took it to the track and everything went alright. Now it's emissions time and then enjoy it for a while. I have a friend who plans to sell his 67 I believe Mustang coupe in Berlin. They were looking to get $8000 I believe and the car actually was restored on a rotissere... It has been sitting but last I knew it looked real nice.
zach103
Re: Next Project
ya i want one that i can fix up a little.. nthing crazy but some restore..
well i tried to do some glassing but the resin harded within a couple mins.. so i took a break..
but i got a question for you guys.. whats the easiest way to fill the all the holes in the dash from previous guages and shtuff
Willyclay
Re: Next Project
Make a new skin over the old dash with plywood and then glass over it.
zach103
Re: Next Project
ok so not much but i finally got the rusted steering wheel off.. took an arsenal of tools but i got it.. and than almost finished the deck
