Lou C
- Nov 10, 2002
- 13,284
I noticed the throttle valve fluttering in the previous vid as well and that's interesting that it shakes less when hold it down so it is nearly closed...perhaps its letting in more air than the EFI system can compensate for and the rough running is leaness, perhaps also related to the misfire codes....
Wasn't there another person with a problem with a Volvo, who got a new engine from Michigan Motorz who had some similar problem, and was trying to adjust the amount that the throttle valve is supposed to close...I seem to remember that from a month or 2 ago. Other things...idle air control valve? Vacuum leaks? although vacuum leaks often cause a whining or whistling noise...
