First time poster!! Hi guys, I have a '93 90 hp Johnson VRO. Boat had been running fine; however, I had the compression checked and to my disappointment found out that the number one cylinder had no compression WHAT-SO-EVER. Since then I removed the head and found that one piston ring had disintegrated and melted the piston at the side that exits into exhaust. All 4 spark plugs looked the same (i.e., oily and wet with fuel). I removed block, cleaned and honed cylinder, and replaced piston and rings. It runs fine in driveway and compression has been restored. I have always had good pee hole indication and water pressure at gauge, but I replaced T-stats anyway. I am left wondering, however, what other possible problems might have caused it. How does water travel through this motor? Any suggestions would be greatly appreciated?
