Re: No Compression on 3 cylinders 140hp Mercruiser
barracuda, Just in-case you are wondering "where I'm going" with this, here is my "train of thought". Air is applied to #3, it is leaking out of spark plug hole of #2.With a leaking valve, the easiest path for the air would be out the intake or the exhaust, it would not end up in the next cylinder. If the rings were bad, it would end up in the crankcase, coming out any number of places, not the next spark plug hole. If the block was cracked, it would either be up high, by the head, which you will see when you remove the head, or it will be lower in the cylinder, and go into the water jacket for that cylinder, once again not back up though the adjacent cylinder.<br />To me, the easiest path for the air to go from one cylinder to the next is through a bad head gasket. There is still the chance of a warped or cracked head, that is why I suggest you have the head checked. By the way, in either case (head gasket or cracked/warped head) there may be something that has caused all of this, such as water intrusion. What did the spark plugs look like ? Any signs of water or rust ?
