I have worked with a lot of aluminum coil stock...I understand your point. I have some aluminum tubing. Is there any reason why Aluminum would be a bad idea?Ayuh,.... You need to build in some sorta structure for strength,...
Properly placed cardboard or plastic tubes, cut in half, 'n glassed over creates stiffness,....
Maybe strips of stiff foam, 'n well glassed over,...
Kinda like workin' tin,.... flat sheets are flimsy,... a few bends in it, 'n it'll support thousands of pounds,....
