CaptainMak
- Apr 28, 2012
- 294
Long story, short. Pulled motor over winter to replace rear main seal, oil pan gasket, intake manifold gaskets, re-installed everything. 305 GM block.
Now starter won't even crank. Very faint clicking with a random hard click.
Battery good.
I DID find a loose, small, black wire that comes from the same bunch as the slave solenoid wires. It is not connected to anything. Thinking this might be the ground I'm missing but here's the problem. I can't find the ground connection for it. The eye is small and there are no bolts that small in the area of the block.
Can anyone tell me where it might ground to? Maybe a pic of the slave cylinder area ? thanks.
Battery good.
