No fwd gear
Senior B
Friend of mine has a 27ft Renken fishing boad with Twin 200 HP1996 Johnsons. The port motor (CCW) stoped working in FWD. The shift cable moves the lever just fine and reverse works fine. Sounds to me like some trouble in the lower unit. The thing doesn't make any grinding noise. Just nothing happens when you attempt to engage fwd gear. Thanks
muskrat
Re: No fwd gear
what the model number of the engine.....
tashasdaddy
Re: No fwd gear
did you disconnect the shift cable and shift the engine manually. could be streched cable.
