Re: No power past the fuse panel
just to make sure i understand what you are saying. biege, lights, trim work correctly but the engine does not start from the switch?.
if this is correct check under the cowling for inline fuses somethimes there are 2 of them. then check the shifter is in nuetral there maybe a saftey switch either under the cowl or in the controller that stops the motor from starting if its in gear (wiggle the shifter while turning the key some times works). a volt meter will be your best friend while trouble shooting like sivertips said as you can see if there is voltage at the small wires on the solinoid.
