No Power
Hashi
Hope all are doing well and staying healthy.
I have an '08 Tracker Marine Tahoe Q7i and after charging the battery (less than a year old). I went to turn on the ignition but there was no sound. Normally, there's a beep and the fuel pump cycles. I thought it might be the ignition switch so I replaced that. Still nothing. Then, I checked all fuses that I can see they're all good. There's no power going to the ignition switch. Am I missing something? The motor is a Mercruiser 5.0. Thank you in advance for your help.
Hashi
I found it!...YIPPEE!!! It was the 50 amp circuit breaker that was under the plastic air filter cover. I just happened to come across it as I was checking the other fuses that I saw from another post. I just pressed the yellow reset lever back into the breaker and now I have power...Happy dance!
Bt Doctur
Dont get too excited, it normally opens up when the batteries are accidentally reversed
