Re: No replys on problem on forum
I can see by your post history what might had happened. You have been here for some time.
Try this
1st clear your cookies but make sure you are set up to accept cookies.
In you browser of choice type in
http://forums.iboats.com/ and that is the main forum page (it lists all the areas). If you are logged in (look in the top right corner) then log out and re-log in. Be sure you are logging in on that main page. [as TD stated make sure you check off the Remember Me box too]
It is possible to be logged in on only one section which causes confusion and I have had the same thing happen. You are not going crazy and I have seen this before
