Eddie Rivera
- Feb 19, 2013
- 183
Need help! 1989 50 HP 2 stroke Force on a 15 Ft. 89 Bayliner. First real boat. I turned it on one time after I purchased it. Installed the ear muffs. They got tangled with the prop. Didn't notice. I noticed it was not cranking at times then it did. I had engaged the gears and wanted to see the prop go. I may have revved it too fast and I saw some sparks out of the stator area. Then I noticed I had ruined my prop my muffs and cracked the starter upper holding bracket. I "think" it did start after that. So I replaced the broken starter upper bracket and purchased a new 27 series battery. My motor cranks strongly but does not even cough or tries to start. I have no spark. Motor started fine till these events took place. Both times we started it was with a car's battery and had to use a bit of starting fluid and it started fast and strong after that. Ok i now took apart the complete ignition system. discovered a burnt section on the stator but the conecting wire within the stator is simply burnt on the insulation part and wire is not broken, at least not visibly I got the trigger and the two coils and the ignition module. but i need help in testing each device for continuity. where do i set my ohm reader at? i get different readings depending on the setting I put it on. While testing the coils and ignition module the reading at a setting of 200 reads 00.00 but what does it mean? All the other settings do give me a reading. I have everything out now. Please help. Desperately need help. Please I've put too much money and endless hours on this little boat for this to happen now.
