I have lost the ignition on my Ocean Pro 150 98`. I am not very good at electronics, but have done some testing with an ordinary multimeter. I have done as follows;
Does anyone have suggestions for further testing?
- Stop Circuit test. Separated the 5-pin connector between the stator and the powerpack. Still no ignition.
- Testing the grounding on the 5-pin connector between the stator and the powerpack. Black meter lead to ground, red meter lead to orange and orange/black. No voltage registered when cranking the engine. (Switched both to 100V and 500V )
- Output test on the 5-pin connector between the stator and the powerpack. Black meter lead to orange stator lead, red meter lead to orange/black stator lead. No Voltage. (Switched both to 100V and 500V )
- I have also tested the resistance on the stator. It shows 0.3, exactly the same as the stator that works on my other Ocean Pro 175
