No spark Evinrude Ocean PRO 150 98`
clanton
If you trust your meter readings, replace the stator. You can check the flywheel magnets when you remove the flywheel.
Andrik
Tanks. How do I chech the magnets? With a screwdriver "dangling" btween my thumb and forefinger about 2,5 cm over the magnet? Fortunately I have another flywheel and stator that I know works.
Andrik
PROBLEM SOLVED; I tried with a bigger battery that managed to make some more RPM. I then got these DVA readings; Between the brown wires; 133 V. Between the orange wires; 58 V. I still got no readings at the primary side of the ignition coils. So I decided to try with anther timing sensor. And suddendly I had ignition on all six plugs.
