No spark!!! Please help
crestflite165
Re: No spark!!! got spark now but gear select probs
ok thats good to know not use anything but whats sposed to be on there. any ideas what could be wrong with it stuck in gear? cables broken maybe? oh and installing a new steering cable on this particular boat was a 4 hour job!!! not to friendly!!
Glastron_V210
Re: No spark!!! Please help
Does the prop **** with force, or is it just coasting along?
I'm inclined to think it's in gear.
Trim that sucker up and check the position of the shift 'foot'.
The shift cable is in two parts. One goes from the lever to an assembly, the other from the assembly to the leg.
The second one of these is called the lower cable. You can remove it and shift the drive manually while the engine is running. It should be easy to get into gear, hard to get out of gear (Stop the engine before pulling too hard).
That will tell you if your cable is intact then go from there.
Chay
crestflite165
what does the "shift foot" look like? sorry new to boats.prop turns one way with force but wont turn the other way at all.
Glastron_V210
It's kinda hard to explain if you don't know. If you've ever pulled the drive you'll know right away. The foot is a 1.5"x.5' oval kinda shaped piece which slides into a shoe (Foot, shoe haha). The shoe rotates and takes the foot with it to change gears from forward to neutral to reverse.
I'd try to remove the lower cable like in my last post.
Dowbnload the manuals from the adults only section...all this will be explained in there.
Chay
