I am not getting any spark on my aq151b. I have new plugs, wires, cap, rotor, stator thing inside the distributor, capacitor and coil. The wire to from the coil to the cap read 12 volts but I am getting zero spark. The battery is reading 12 volts and is cranking the engine over just fine. I did change the timing belt but I checked the marks on the pulleys multiple times.
The only thing I can think of is the cap is not contacting the rotor to give off the spark, if you have any ideas please let me know. I have rotated the motor with the cap off and the distributor shaft does spin.
