No spark
scatgo
Can some one please tell me how to test for voltage at the coil. With the ignition on ill get sparks at the - terminal on the coil when I remove the wire going to the points but Iam not sure how to test to see If I have 12 volts at the + terminal. Is there a way to test the coil?
alldodge
scatgo
Bt Doctur
if you have only 1 wire coming from the dist you have a points ign system
if you have 2 wires coming from the dist you have either an electronic conversion or you have the Thunderbolt IV system
tell us what you see mounted on the port riser/elbow , is there a box mounted there?
scatgo
Points
Cant seem to find a tune up kit for my boat. Can anyone help with that?
Bt Doctur
post some pics using photobucket.com either Mallory or prestolite
Fishermark
Where have you been looking? All kinds of places sell points, condenser, etc. Many will need your serial number. If you have that it makes life easy.
